okay, so i need some confirmation on the timing on my friend's ka24de.
motor's set at TDC...would it be fine if i just set the cams with the lobes for cylinder 1 facing horizontally outwards from the middle of the motor?
and does it matter if the idler shaft/tensioner isnt completely perfect according to the fsm, but is very close and all of the chains fit fine?
