spitfirebill »
https://forums.nicoclub.com/spitfirebill-u258920.html
Fri Mar 25, 2016 9:07 am
If it runs on ether, it sounds like you have a fuel feed issue despite good fuel pressure.
My truck sat for several years while I tried half-heartedly looking for a good used engine. I ended up rebuilding mine. I had to have the injectors professionally cleaned as they were stick. Once back together it would only run when I dribbled fuel into the throttle body. I put in a good fuel pump and same thing. I weed up having it towed to a good auto-electric guy who discovered the ECU was not sending a ground signal to the fuel pump. He ran another wire and hooked it up and it ran. The engine only cost around 600 for the machine work and engine kit. But I spent a lot more than that afterward replacing other things like TPS, MAF sensor, the heater on the intake, etc. Truck ran great for several years, but is now not idling worth a crap. I'm going to take it to a shop. Tired of dealing with it.
