Nissan 100K Extended warranty
06pathyman
Car: 2006 Pathfinder LE
Does anyone know a good place to find information on what is covered and what voids the Nissan 100K extended warranty. I wanted to install an amp and sub. but I don't want to run the risk of voiding my warranty. I can't find to much info... I found one site but it seems a bit confusing. Anyways, thanks you guys. Hopefully this post will help others as the Nissan Guru's reply.. Thanks again
Kidastra
Car: 2003 Nissan Pathfiner
really it depends on your dealer, almost everything not done at the dealer will void your warranty, but I've never seen anyone say "oh your motor is fried because of your headunit" installing a radio and sub should be safe if done properly, not much can go wrong there.
Kidastra
mind you, you can always install it, and before going in for anything warranty related swap back to original
K03sport
Car: 04 Pathfinder. My first Nissan was a '72 Datsun 510 Wagon.
Kidastra wrote:mind you, you can always install it, and before going in for anything warranty related swap back to original
a new stereo might void the electrical system.
wheels and tires could void the suspension and driveline
an intake can void the engine
an air freshener will void everything else...
and the sad part is, despite the Magnason-Moss Act, it is all up to the attitude of the dealer. If they will get reimbursed for the time, then they will cover it, if they don't, then you are poop out of luck.
Adnan
Car: 2001 Pathfinder LE 4WD
your best bet is to ask the dealer,technically they should explain to you exactly what is covered and what isnt.It now a law here in Ontario,the dealer must include a written report of the warranty coverage an what could possibly void it
