nismojame?
BRADYNS240SX
Car: 1989 240SX SR20 SWAP
I attached a link below for an lsd on ebay. I am going to put it on my 89 240sx w/sr swap. does this have everything I will need? Just copy and past all info below and paste into search field it should pop up. Thanks in advance...........
http://cgi.ebay.com/ebaymotors...ZWDVW
ILikeMy240sx
Car: SR Power
What is this about? link no workie.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Is your 240 currently Open diff or VLSD? It makes a difference.
BRADYNS240SX
Open diff
redtop91
Make sure the kit you are buying is for 240's with the open diff pumpkin. Also work on fixing the link so we can give better advice.
BRADYNS240SX
I e-mailed it to you................ ILikeMy240sx
BRADYNS240SX
I emailed it to you redtop91
redtop91
There is no link in the email.
BRADYNS240SX
I suck *** at attaching links...I sent you the the entire address. See if you can copy and past that into the address line and get to it. If not can you give me some pointers on attaching links to this forum or anywhere in that case.
Thanks
redtop91
I got to it actually. I replied in your other thread
redtop91 wrote:^ Perfectly said. VLSD's are not worth it especially at that price plus shipping. If you want a VLSD just buy a J30 VLSD from a junkyard for around 100 bucks.
240 GTR
Car: '98 Nissan 240SX
2006 Yamaha Raptor 700R
edit: nevermind.
just be careful buying stuff from ebay
NismoJame
Car: S14
( igot it now )
KAAZ 2 way man the best or cheap way Weld (for dragracing).Also J30 5 bolt aronud $100-$150
(KING of SR in Ann arbor)S14 RHD silvia GT2835R (320Whp @1.2 bar)S14 HKS2.2 GT42RL AEM EMS (1000hp@3 bar) Switzer engineeringDSM 2.4 (600hp @39psi)S13 13B RE TO4Z (Coming)
(9K+REV stock block/ECU = BOOM BOOM BOOM )
Modified by NismoJame at 6:49 PM 5/7/2007
CMG
Car: 1989 240sx Hatch w/ Redtop
Get an S13 R200 for around $300 max. All you need is the diff and shafts, most likely it will be 5 bolt if coming if JDM. Throw some synthetic 90w/145 in and you're set. Simple straight swap.
