Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Fri Aug 10, 2007 6:48 pm
I have the same impossible to remove water spots.... until tonight!
Get a brand new razor blade. After the glass is super clean, use the blade to remove the water spots. Change the blade you are using a lot, so as to not take any chances of scratching the glass.
After the spots are gone, clean with window cleaner, and look at how clear they are!
I also found a window cleaner by "Griot's Garage" and it has a high alcohol content, and dries streak free. Cleans really well!
