nismo wheel studs 50mm or 60mm?
smokey240sx
I just order my studs from Courtesy Nissan. I just installed z32 calipers and had to run 1/4 spacers to make them fit on the oem rims. (dammit i swore my rims would clear.) Would it be better if I had ordered the 50mm rather than the 60mm? I thought I had already did my homework.
Modified by smokey240sx at 7:53 PM 6/18/2005
chmercer
get a set of open ended lug nuts and the 60mm studs. its like the same price, and if you want to run more spacers later, you have an extra 10mm to work with
smokey240sx
thanks I never knew they has open end lugs. so do this mean I have to get knew lugs now?
smokey240sx
RESULT:
I just want to thank Courtesy Nissan for next daying my Nismo 60mm studs. I had to get another 1/4" spacer to bolt down the lugs. I could get away from just one 1/4" spacer if I get new lugs.
chmercer
just get a set of the gorilla open ended lug nuts, then you wont have to run more spacer than you want. unless you like the 1/4" spacer on there
