float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Nov 22, 2007 5:36 pm
What do you mean? The thermostat controls the temperature of the engine. It's closed which keeps the radiator out of the loop. This heats up the coolant in the block until it starts to reach the opening point of the thermostat. It then starts to circulate the hot coolant into the radiator. The cooled down coolant is circulated into the block and cools it's temperature down. This will continue until the radiator can't take the heat out faster than the engine is putting it in. Then the temps start to climb. At some point the fans come on and start cooling the radiator down, which cools the coolant off.
The thermostat is a 100% seal. So if you've got your fans on, the temp of the coolant drops way down and so very cold (ambient temp) coolant re-enters the engine. This can allow the temps to remain below the opening point of the the thermostat.
Generally you want to have the car set up so that the thermostat will control the temps under normal conditions and the fan isn't needed until you come to a stop or are idle for extended periods of time.
My fans NEVER come on during the summer unless I'm sitting in traffic. I've got them set up so that they come on when the engine temps get about 10-15° above the thermostat temp, and then turn back off at about 5-10° above the thermostats opening point.
