Nismo S13 Extended Studs Don't Fit Right...Help
240sxOwner
Car: 93 240sx
I bought the extended studs from my local nissan dealer and as i went to put them in today, they do not seat correctly on the hub. The Nismo studs have a thinner head than the stock ones, thus they are loose and angled causing my wheel to wabble. I have the 300zx TT brakes and a spacer for my rims, that is why i must use these studs. Has anyone in here used these studs, or know how i can fix it. Thanks For the Help....
Exar-Kun
Car: 2005 350Z
you sure you got the right ones? theres 2 different NISMO stronger/longer studs..-chet
240sxOwner
Car: 93 240sx
I went to the dealer and told them the model car and everything, but the nissan dealer in my area are a bunch of idiots when it comes to parts.
240sxOwner
Car: 93 240sx
Is anyone using these studs? Do the two different studs for the 240 have different heads to fit into the hub? I need help asap, i have no car until i find a solution. I tried calling Nissan Motorsports but they will be closed until the 2nd on the year. Thanks for the help.
gema
Post the part number, I'll check it on Friday and see which models/production dates it's compatible with. You may have the right part and simply need another part to install it, or your dealer could've screwed up. Happy Holidays.
Exar-Kun
Car: 2005 350Z
http://www.courtesyparts.com/n....html
check that for reference, then tell your local dealer with part you need :)
-chet
rudee023
Car: '03 Infiniti Q45
I am running those studs on my S13. They fit fine. You probably got the wrong number. There ARE two different part numbers for S13 and S14. Courtesy parts says so. Pk103 and 104 are S13. Pk105 and 106 are S14.
240sxOwner
Car: 93 240sx
Ok guys...i looked at the part number on the box and this is what i have... 40222-RS045 This number is from the back of the Nismo Box....I am going to the dealer tomorrow to order some more.
