NISMO S-Tune Shock & Spring Suspension who has seen or tried it??
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
I dont want a full coilover setup for my daily driver but I saw these
http://www.mynismo.com/products/?id=2449
anybody have any info on them such as ride harshness and spring rate
thanks
jason
p.s. yes i tried searchin and didnt find anything
pull'nslide
Car: s14 Kouki
I use to think of getting them, only problem I saw was the car stance still looked high, other then that, I've heard AWESOME things, bumps will be more noticeable but totally livable.
spider_slayer
Car: S14 240SX
S13 240SX
i think that rico05 and ilikemy240sx both have s-tunes. ask them.
hybrid_flyer
spider_slayer wrote:i think that rico05 and ilikemy240sx both have s-tunes. ask them.
thanks for the tip i'll pm them
hmmm could not find ilikemy240sx ??? i think the name is wrong
haha nm i found him
Modified by hybrid_flyer at 9:10 PM 1/12/2007
Modified by hybrid_flyer at 9:13 PM 1/12/2007
AmoebAssassin
Car: 1991 Base fastback 5spd, black
They're KYB dampers and some random springs. You may as well just buy KYB dampers and some good springs, and save yourself a boatload of cash. Unless you're dumb enough to pay like, a few hundred extra bucks because they're OMG NISMO TYTE SUSPENSHUNZZZ LOLOLOL.
They're also non-adjustable and have pretty weak spring rates, and not enough drop. Save yourself the hassle and just buy some coilovers, I'm pretty sure the megans are cheaper than the nismo "coilovers."
And trust me. As you progress as a driver, you will notice spring/shock combos start to let you down as you learn to handle and expect fast load transfer in corners. You're now going to have to spend even more money buying the coilovers you shoulda bought in the first place, or big roll bars to try to band-aid the squishy, inadequate nismo suspension.
hybrid_flyer
hmmm i thought they were actually R&D'd by nissan not just tossed together with the name attached. If that is the case I will probably go with the swift springs, and koni shocks. Coilovers arent really in the plans for this car...but in the other car I am probably gonna run stances
SimpleEnigma
Car: 1992 240sx Coupe
the S-tune are a step up from the stock suspension.
No, they don't have the ridiculous spring rates, or the ride height adjustablilty, or even damper rate control, HOWEVER, I have had mine for a little while now, and i would say that they are a significant improvement over stock. For a daily driver/occasional weekend racer and as a starter suspension, I would say these are quite adequate.
These could probably use a little more drop to them (1.0" F, 0.6" R), which, if they did, would have to go to stiffer spring rates/damper rates (NISMO R-Tune anyone?) but it looks a hell of a lot better than stock, curbs and speed bumps are not my friend.
Stock spring rates = 2kg/mm F&R
NISMO S-Tune = 520 N/mm F and 373 N/mm R
Sorry to dig this back up, but i like mine.
bware113
Car: '02 BMW TS M3
1990 Piggy Hatch
Sorry to re-digg this up but may I get a picture of someone's car with this shock/spring setup was looking into buying and am doing a little research.Thanks
adrianfromthecastle
Car: 1992 Nissan 240sx
bware113 wrote:Sorry to re-digg this up but may I get a picture of someone's car with this shock/spring setup was looking into buying and am doing a little research.Thanks
