StuartTheFish wrote: ↑Sat Dec 10, 2022 3:00 pm
Our current IPDM is labelled as S1, so I assume if there's no power I'd need to find another S1 version so it's coded correctly for the car? So not like other modern cars where you could just code it yourself. Speaking of coding, is it possible that the DRL's could be deactivated in the BCM? Or are they not able to be coded either?
The outside markings can't be trusted except for the Nissan part number, which will be 284B7-something. I don't actually think you'll have an easy time finding one for a Nismo (they
are different, plus there are three different Nismo variations). The IPDM and BCM are the two control units on the vehicle which are strictly not reprogrammable, due to security concerns.
That all said, if the DRL Relay is the only thing not working, it's pretty easy to rig a pair of parts store relays and two diodes to run them instead if the IPDM. The fuel pump fuse gets juice only when the engine is running, so one relay triggered off the pump and another "cut relay" diode-wired to both the low and high beams will give you DRL's only when running with the headlights off.
