Ok, after spending ALL evening researching this crap this is what I have come down to.
I currently have Tokico blues and ebay cheapo coilovers (See other thread if you must)
First I was looking at coilovers, specifically Stance. - to expenive/stiffThen i was looking at koni yellows & RSR race springs - install issues, still kinda stiff and expensive, race springs to stiff for anything but koni... SOThen I was looking at Nismo S-tuned - great price from midway, matched spring struts, but not enough drop, would actually RAISE my car.
Now I'm looking at Kyb AGX with some RSR ti2000 springs. The struts are adjustable and these springs seem to be new as I cant find much info on here about them. But they have the same stats as RSR down springs, but lighter and stronger.
http://www.rs-r.com/products/suspension/ti2000.php
SPECS:Nismo 685 shipped from midwayFront:Rebound: 353lbfCompression: 160lbf5.34 kg/mm 1 in drop
Rear:Rebound: 323lbfCompression: 124lbf3.75 kg/mm .6 in drop
AGX&ti2000775 shipped from intense and tirerackFront:adjustable ~115-2233 kg/mm1.6 in drop
Rearadjustable ~115-2233 KG/MM1.2 In drop
So based on what I have foundnismo (uses KYB)plus: Price, matched set.neg: drop, non adjustableVSKYB & RSRplus: drop, adjustable.neg: unmatched set
And of course the price difference goes out the window if i just get RSR down instead of the ti2000 springs...
Both will be quality nismo vs top of the line RSR springs, both use KYB shocks.
Unkown: (affected by spring rates/dampening/matched sets)wich would be better performancewich would be better ride quality.
Ive also emailed rsr asking what struts they would recamend with the ti2000 springs IF not the AGX's
can anybody else think of pos/negs of each setup? instalation issues? (hopefull easier than koni inserts) comments suggestions?
Modified by glitched at 11:25 PM 9/25/2006
