nismo oil tee - brass?
jt15833
Car: 95' 240SX
it looks as its made of brass, I hear that people having cracking issues with oil tee's made of brass and aluminum. anyone ever encountered this?
teddy
Car: Saab Turbo and MR2
It's made of brass.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
most brass tees are rated for like +16K psi or something and heat resitsant to pretty high temps
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Not_a_sr wrote:most brass tees are rated for like +16K psi or something and heat resitsant to pretty high temps
That's what I was thinking...
jt15833
Car: 95' 240SX
its not the pressure its the vibrations in that area and brass being a very soft metal, just what i've heard but if no one's having issues then ok
nismoplsr
I havent had any problems nor has anyone i know.
float_6969
Mines been on for about 5K miles now w/o any problems. I'd say it's fine. It't not like NISMO is infamous for selling crap...
sideways danny
Car: s13, CA18DET
I've seen 2 break and heard of a couple of others. It seems to be the weight of sender units causes the problem. the solution seems to be fitting a flexible hose to the sender and attaching it with no weight on the T
jt15833
Car: 95' 240SX
i got a 90* fittng and bspt*npt adapter from mcmaster carr for 18 dollars, galvanized steel sending units arent exactly heavy so i think the cracking is induced by soft metal and vibrations. nismo sells good stuff but there oil tee is $9 and its a brass bspt-npt adapter and a T, i doubt they put alot of engineering effort towards it
top_secret
msmaster carr is what I run but mine is brass as well and I've had no problems.
