Situation:
Sr swap in 1989 hatch. Using nismo mounts. Got the engine in first without the trans and Im glad that we did it that way. Now I know I must do something because Im not going thru this hell when is time to swap the clutch.
I spend the whole day trying to get the trans in. The engine sits too high. The top of the bell housing hits regardless of what technique used, for example:
transmission-install-tips-t318898.html
I tried this one as a last resort and I still have no clearance enough. I tried the "starter hump pointing down" technique and no dice. Well, the engine looked like it was sitting kind of high and it is. I cant even close the hood, is that bad. Even with the engine support dangling.
I checked the NIsmo mount to the OEM one and they are identical. But then is it the design of the engine...?? What are my options?
Tried different mounts or hammer the trans tunnel and cut the hood skeleton for clearance?? Sorry about the long post, I really need help on this one....
