NISMO mounts are incredible!
unfrgivn
Just installed my NISMO mounts last weekend and it is like driving a new car. My engine used to shake like around like a mother and no it's rock solid. The car doesn't shake when I launch and everything just feels smoother.
I Highly reccomend these mounts!
zion
Car: cars, guns, the usual
where, and how much did you get them for?
Wuss
what's the install like? I'm putting in my SR this weekend, but with everything else I bought, motor mounts weren't in the install budget, so I'm going to do it in another month.
Easy? please don't tell me you had to pull the motor....
quiksilvia
Car: 95 s14 se
u have to get enough clearance to get the old mounts out, so u have to pull the motor a little bit
SWIFT_DRIFT
I have Kazama mounts in my car. They are about a billion times beefier then the stock copy Nismo mounts.
Otherwise swapping the mounts is simple with the motor out. However, with the motor in you either need to pull it out a bit to make room to get the old mounts out, or drop the front crossmember...Either way it's a pain, but definitely worth the effort if your old mounts are shot.
Wuss
could you just jack up the motor from below?
SWIFT_DRIFT
I highly doubt you would have enough clearance without actually taking the motor half way out or dropping the front crossmember. The studs on the mounts are at least half an inch long or more on each side. So, that's over an inch of clearence you need to unbolt them from top and bottom and pull them out.
captain nismo
So this mounts will stop or at least lessen the diesel truck shaking i have now with my KA? If so, when i swap. i'll definatly jump on them.
LittleBrotherSilvia
Car: wakeskating/wakeboarding, motocross
Wuss wrote:what's the install like? I'm putting in my SR this weekend, but with everything else I bought, motor mounts weren't in the install budget, so I'm going to do it in another month.
you are gonna have one hell of a time changing the mounts after you put the motor in.
i found it easier to unbolt the bracket on the passenger side of the sr20 that the motor mount mounts to, and connect the mount and that bracket to the cross member before i put the motor in, then reconnect the bracket to the car. on the drivers side i just connected the motor mount to the motor before i dropped it in.
Machine
you dont NEED new mounts, what some people do is stuff the old mounts with polyurethane, which wont wear out like the nismo rubber ones, plus i think it can be done with the mounts installed.
zion
SWIFT_DRIFT wrote:I have Kazama mounts in my car. They are about a billion times beefier then the stock copy Nismo mounts.
Where did you get you Kazama Mounts at?
Redline240
Car: 95 240sx
Machine wrote:you dont NEED new mounts, what some people do is stuff the old mounts with polyurethane, which wont wear out like the nismo rubber ones, plus i think it can be done with the mounts installed.
Arn't the Nismo ones made of Derlin? Derlin being stronger than polyurethane...i doubt they're gonna wear like rubber ones...
Redline
SWIFT_DRIFT
Anyone taken a close look at the Nismo mounts? They are basically stock mounts with stronger rubber, if that. And no they are not made out of delrin...
I have the Kazama engine mounts and a Nismo transmission mount. I don't remember where I got the Kazama mounts I ordered them a long time ago, and I got the Nismo mount from a local dealer. I love the Kazama mounts, they are made from poly bushings and fat metal with big bolts basically. I notice more chassis chatter at idle, but I also have no interior at the moment...so everything is louder and it's hard to tell. Anyways I have no engine or transmission shake, launches and acceleration are silky smooth. However, the transmission mount is so-so in my opinion. I'm not too impressed with it right now. For some reason the mount aligned the transmission about 1/2" to the right on the transmission brace...Everything is installed correctly, I'm not a retard. So, maybe I just got a strangely built mount or then again Nismo sucks...oh well. I think I'll get that poly Uras transmission mount and install it when I'm doing my testpipe later.
SpeedRacer1
Car: 1990 240SX, G35
SWIFT_DRIFT wrote:I'm not a retard.
You dont know when to shut your mouth do you tardo boy!
SWIFT_DRIFT
SpeedRacer1 wrote:You dont know when to shut your mouth do you tardo boy!
Touche, Mr. I-put-2-exhaust-cams-in-my-car!
:cuddle
SpeedRacer1
SWIFT_DRIFT wrote:Touche, Mr. I-put-2-exhaust-cams-in-my-car!
:cuddle
Double touche, MR. I-helped-the-guy-put-two-exhaust-cams-in-his-car!
Tai Mai Shu
so my question is...where is the 2 intake cams....:D
pgt892
Car: 1997 240SX
After reading this thread on the Nismo mounts and there rock-solid engine abilities, I am starting to wonder on whether or not I have Nismo mounts. My motor vibrates a little under idle and moves a couple of inches while revving it up. Afterdark did the install and SUPPOSEDLY put the mounts in, but alas the movements would suggest otherwise. Are there any identifying marks or anything that I could easily tell if my engine mounts and transmission mount were of the Nismo variety, without pulling the motor? Thanks in advance.
SWIFT_DRIFT
No, they look identical to stock mounts. Depending on how long ago they were "installed" and if they really are new, you should see shiny black mounts sitting right there (at least theoretically).
Not really sure how much of this thread you read...but I already said Nismo mounts look identical and perform and most likely are just hyped up stock mounts. The rubber might be slightly "stronger" but the motor mounts are filled with the same goo like stock mounts.
And you have to realize if you replace the stock mounts and notice an improvement, well duh. You just put a new part in place of an old part :rolleyes.
SpeedRacer1
Or you could always buy a piece of strong wood to make mounts out of. :P
OR get some thick metal have one stud on each side thus resulting in ZERO flex!
captain nismo
So what are the best mounts then?
SWIFT_DRIFT
Your preference.
captain nismo
SWIFT_DRIFT wrote:Your preference.
lol. thanks swift. What i mean is, how much better are the ones that you have and are they substainally more money than the nismo mounts?
Tai Mai Shu
Window weld the whole motor mount thats what all the cool kids are doing...
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
http://www.enjukuracing.com has motor mounts on their SR page, both sets if I remember correctly.
Check them out
Paul
unfrgivn
Window welding is very DSM of you! I just jaced up the motor by the oil pan and easily enough clearance to cram them in there.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
unfrgivn wrote:I just jacked up the motor by the oil pan
please tell me you at least put a wood board in between to disperse the pressure across the whole pan. dont want any SR's driving around with pinched off oil pickups :)
Zaxx84
Anyone looking for Nismo mounts at a decent price needs to go here: http://www.courtesyparts.com/n....html By far the cheapest I have seen them at only $208.34 for the complete set.
Onizuka
i got mine for $185 shipped :)
edit: wait i minute, maybe i didnt, not sure. all i know for certain is i got them from limecreekmotorsports.com and it was the best deal at the time.
NeedCAforS13
Car: CA swapped S13 coupe
no way! really? Thats what I paid and I work at Nissan... you got a damn good deal Matt:)
Sean
