S13 Charlie wrote:The only reason the engine will sit higher is because your mounts are probably 10-15 years old. The rubber ages, and the engine sags. Installing new mounts just puts the engine back to where it originally sat.
I should be installing nismo mounts (engine and transmission) this weekend, SPL subframe collars too - hopefully
Do you guys know if the nismo motor mounts that are for ka24de work for ka24e also? And for the transmission mount as well and for manual or auto - does it matter?
Thanks
****Edit: Found out that they are all compatible***
Modified by brokeAs240sx at 3:54 PM 3/24/2005
