zer0c123 »
https://forums.nicoclub.com/zer0c123-u10125.html
Sat Jul 01, 2006 7:07 pm
Finally got the mounts in.
In order to get the mounts in, we dropped the front cross member by an inch for the mounts to get into the holes. It's just 2 bolts on each side to loosen the cross member.
As for switching left and right sides, we did that. We put L and R and L and R. We really debated on what to do, but my friend was saying these were made for SR;s so their R means driver side. Since drivers side is on the right in japan, then we should put L on R on my 240. SOunded weird, but made sense in some way, so we went with it.
You don't have to worry about the denting the hole pan as long as a piece of wood is used. The load will be distributed over a bigger area and not a single point that would cause a dent.
