Nismo_Freak
scruffy63
Car: my nissan 240sx
hey I'm trying to pass emissions and i'm having a little trouble I took your advice and sprayed a bunch of windex on my muffler tip right before but I still failed. I actually scored worse this time. and its always nox that I fail.I also had denatured alcohol in my gas tank it ( tank was almost on e) do you have any other ideas as to what my problem could be?
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
thats easy, NOx means you have a high combustion temp. Figure out why. Is your EGR functioning properly? The most common problem is an EGR that isnt working properly. But NOx always means that your combustion temp is above 2500 degrees
