Nismo FPR question
Lantz
Car: '96 240sx KA-T (kouki conversion)
I need to run an fpr cause my ka-t is running waaayyy to rich. I would like to use the nismo fpr because it looks like it bolts right on to the stock fuel rail and its reliable. This may seem like a dumb question but how do you accuratly adjust a nismo fpr (or any other fpr that doesnt have a gauge on it). Do you have to have an in-cabin fuel pressure gauge or is there another way? Also if anyone knows the correct hose-on/hose-off pressure to set it for i would appreciate it. Searching got me mixed responses.Let me know. Thanks
-Lance
Florida240sx
I think what you are looking at is the adapter.... which replaces your stock FPR, then you use and adjsutable fpr to adjust the psi.... I run the megan racing FPR with the nismo B fpr adapter...
MarkEmark
Car: fully-built '95 240sx KA-T
No, there's no in-cabin fuel pressure gauge, nor is it read via OBD II...my suggestion is that you get an adaptor and use a remote fuel pressure regulator with a built in gauge...it's a lot easier to install too because the nipple for the fuel hose isn't pointed/wedged against the firewall...
not to mention, for the money, an aeromotive or megan unit seems to be of a lot higher quality
Lantz
Thanks guys, I think i'll do the remote one and use an OBX frp with a gauge.
Is this the adapter you guys use?http://www.courtesyparts.com/M...Code=
or this one?http://www.courtesyparts.com/M...Code=
Also what do you recomend to set pressure at?
KATwo40
Car: 1993 240sx KA-T
MarkEmark wrote:No, there's no in-cabin fuel pressure gauge, nor is it read via OBD II...my suggestion is that you get an adaptor and use a remote fuel pressure regulator with a built in gauge...it's a lot easier to install too because the nipple for the fuel hose isn't pointed/wedged against the firewall...
Hehe, you said "nipple."
Florida240sx
Child......
KATwo40
Just havin' a little fun. Hope no one was offended.
hek1620
Car: '89 240sx
well sir, i was deeply offended. j/k
crzycav86
Car: 93 Nissan 240SX KAT
KATwo40 wrote:Hehe, you said "nipple."
that's not the first time you've commented on the word nipple. is there something we should know?
crzycav86
Lantz wrote:Also what do you recomend to set pressure at?
it depends mainly on the size of your injectors, your tune, and how rich your motor is running.
KATwo40
Any man who doesn't think the word "nipple" is funny on at least the smallest level, well...just isn't really a man.
Edited...
Modified by KATwo40 at 3:15 PM 9/22/2006
Florida240sx
It is funny.....and we all liek them....but someitmes it's best just to imagine what you like rather than to post about it.....because "they" are watching...
KATwo40
^^^ Quite right. I edited my previous post. (Gif image)
Lantz
yes nipples are great n all that, but......
Which adapter am I suppose to use
This onehttp://www.courtesyparts.com/M...Code=
onosqv
Car: '92 240sx Vert
either one will work. I'm using the nismo one - one piece, nissan made, rather go w/ that.
