UPDATE--
I was just about to order that expensive $62 JUN fitting and my dad was like "save your money, I can make one pretty easily," and I guess he was really bored today, because when I came home, he had a fitting all made up, using the other fuel rail I have lying around to get measurements, etc....I'm so glad I have a dad who loves working with metal
I'm also pretty fortunate to have a very nice lathe right in the work shop.
The piece that actually will sit in the fuel rail with the o-ring was fabricated from scratch out of VERY hard steel, as was the metal flange that screws into the fuel rail; then everything was soldered together. Looks very nice, and I was shocked to just come home and see it sitting there!
I'm pretty sure i'm going to be going with the Aeromotive adjustable fuel pressure regulator, but the one I want has 2 inlets, one outlet, so one of the ports will need to be plugged, and I need to buy fittings for the 6AN inlets/outlets so that there is a barb on the end as to just run regular hose.
The reason I'm weary of aeromotive is because their stuff is all for high horsepower applications--and I hope that the fuel delivery wouldn't be any more inconsistent at lower power/flow levels if it was designed for such power.
I'll keep ya guys posted.
Links to pics of the fitting:
http://www.imagestation.com/my...9_img
http://www.imagestation.com/my...0_img
