i just tried that out im now running upper 12's at idle wot is low 11's i think i may have a vacuum leak my avcr says im running 53-54 in/hg at idle im not sure how much vacuum im suppose to have but is that low?DrifterProdigy85 wrote:Set to 43psi w/o vacuum. Make sure the engine is warmed up and you drive the car before setting the fuel pressure. Fuel pressure runs high before the engine is warmed up and driven.
