biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Thu Feb 03, 2005 11:06 pm
KA and SR are same mounts.only CA is different.
And yeah, had a hard time getting that transmission subframe in place.. I managed to brute force it far enough in that I could get one bolt in (I was pushing w/ feet on the rear LCAs and hands on the subframe, from underneath) and after that took a bigass screwdriver so I could jab it in sideways through the subframe and bolt hole and push it straight, then get one on the other side boltedu p... then it was smooth sailing...
next time I'll do as the various swap guides say to do and put the engine+transmission in at once, at least then I'll only be fighting with part of it not both at the same time (since were trying to mate engine and t ranny at the same time as get subframe bolted up, as one would help the other once its in place but both are hindering each other getting there)
