Nismo Engine mount
ser20det
Car: Silvia K's 88
I'm installing Nismo Motor mount right now.
I wanted to know if there would be any problem if i remove the triangle support between the intake and the motor mount bracket and run it like this ?
As far as i know guy with aftermarket intake manifold don't use it like meminto on is beast ca18.
What do you think about it ? keep it there or ditch it ?
bentvalves
Car: 89 Silvia K's
Lot of us with stock manifolds have also ditched this brace, and the ones above the fuel injectors as well.
ser20det
Car: Silvia K's 88
ks13 wrote:Lot of us with stock manifolds have also ditched this brace, and the ones above the fuel injectors as well.
The bracket above the injectors ? Wich one are you talking about ? The one between the firewall and the intake ?
no problem after doing this ?
Cause i was thinking that maybe it would may leak intake manifold gasket.
Plus it's a 3.5lbs weight reduction
Modified by ser20det at 5:46 PM 3/15/2009
float_6969
My vote? Nissan put it there for a reason. That is a lot of weight to be hanging off the side of the motor vibrating all to heck.
