xjmxstac »
https://forums.nicoclub.com/xjmxstac-u90733.html
Thu Apr 30, 2009 8:52 am
The Nismo S-tune is your stock exhaust, which is not bad, but there are better. Put some decent headers, Test pipes/Hi Flow cats, and a decent midpipe and you should get some more hp out of it. Throw in a good set of pulleys, and a lightweight flywheel to free up more HP. The next step after that is F/I (safe to about 400whp with your stock internals). Going F/I will put some stress to your engine cutting its lifespan short. Unless you want to go all motor, which will cost you 5 times the cost of F/I for a less hp. Fully built N/A motors offer a smooth, reliable power across the RPM range.Good Luck!
Modified by xjmxstac at 12:01 PM 4/30/2009
