NISMO IDx Concept
Nissan says the concept is aimed at the youth that is generally disinterested in cars.
Nissan hopes to build it with a RWD powertrain and a 1.6L Direct-Injected turbocharged inline four similar to what is found in the Juke NISMO. This is seen by many as an homage to the Datsun 510 and many are hopeful that Nissan builds what will be its answer to the affordable sports car market.
NISMO Sentra Concept
240hp and 240lb-ft of torque from a 1.8L Direct-Injected Turbocharged inline four cylinder engine. That power will be channeled to the front wheels via a helical limited slip differential and threaded through a six speed manual transmission. This concept is likely closer to reality and could be available as soon as MY 2015.
