NISMO clutches and Cover part numbers CA vs KA
CA19DET
ok i have been looking around at NISMO clutches, clutch covers, presure plates and flywheels, the KA24E and CA18DET booth use a 225mm clutch, the difference seems to be the cover. so if you got a NISMO KA24E/CA18DET 225mm clutch you need the corisponding CA18DET Nismo Cover. here is what i ahve found on http://www.nismoparts.com http://www.nismo.co.jp (trnaslated via babefish) and http://www.japanparts.com
Above - OE NISMO ClutchNISMOparts.com has the NISMO clutch for the CA18/KA24 part number is: - M-30100-RN225 (NISMO lists this as the NON-GROUND i guess this means it's kinda OE maybe a little better)
the NISMO catalouge has the CA18DET high performance clutch part numbers as:
- ceramic-metal A: 30100-RS550*
- ceramic-metal B: 30100-RS500*
* You must use the 750kg NISMO cover with this clutch,
the clutch cover listed on the NISMOparts.com website is the wrong cover for the CA18DET (M-30210-RS600) it is the one that needs modification to work.
Above - The NISMO CA18DET Clutch Coverthe 750kg NISMO Clutch Cover part number for the CA18DET us:- 30210-RS550
now NISMO also lists a "Kappa" Clutch that i guess is some kind of carbon composit clutch, who knows it clamping force capabilities? Part Number is:- 30100-RS225
all these sites have good prices, nismoparts.com i think is a US company and could source anyparts not in stock, i'll be emailing them later with the clutch & cover part numbers i want later to see what they have instock and what they can get,
i am looking a the NISMO 750kg Cover & Cerametallic B Disk w/ TO bearing
Question is there is no Part Number for a NISMO Lightened Flywheel in the NISMO catalouge, will the NISMO KA24E lightweight flywheel work?? it should?
here are the links to the websites mentioned in this post:
NISMOparts.com - USA NISMO distributor
JapanParts.com - Overseas NISMO distributor in Japan.
NISMO.co.jp - Official NISMO website and parts catalouge
CA19DET
Courtesy Nissan also supplies NISMO Stuff, and they are making an order for JULY 1st of NISMO parts from japan, anyone want to order NISMO Clutches & Covers ??
Courtesy Nissan Link:- http://www.courtesyparts.com/nismo/s13/s13_4.html
