nismo clutch
Nissan 350z / Nissan 370z general community discussion forum
sliver
Car: 2003 350z
hello all. i have a question i hope someone cal help me with. i have a 2003 350z. i got the clutch replaced with the nismo clutch and lightweight flywheel and now i have some rattling sounds. i figured it was the heat shield or whatever but the mechanic who did the work says it's the clutch and it's "working as intended." this dosen't make much sence to me but i'm not exactly mechanically enclined. is this guy taking me to the cleaners? i expected more vibration but the rattle comes and goes. usally when i'm in the low end of a gear. any ideas?
Anthonysflying
Car: 2004 Silverstone 350z Touring
In the Nismo catalog it mentions that the clutch will add some rattling...i get that noise too but i haven't confirmed my clutch type yet. did the clutch smooth up your travel between gears?
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
You will also get a little bit of noise from light weight flywheels as well.
sliver
Car: 2003 350z
ya the clutch took some getting used to hehe. shifts are smooth and fast. i'm happy with the performance. it's just the rattle here and there i don't like. the mechanic mentioned that this clutch had no springs versus the OEM one. not sure if that has anything to do with it.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'm prettu sure the nismo disk uses a sprung hub, I ran a nismo disk in my S30 for a while, I caught it on fire, well ok it was just smouldering but still kinda crappy, I now run Competition clutches stage 4 and even it has a sprung hub, generally speaking nismoperformance parts tend to be fairly tame
dasoupdude
Car: 2005 Nissan 350Z
hmm all i know is that when i first get in the car in the morning and drive down my neighborhood as i hit the clutch to go to second it makes this dread rattly sound, i wonder if my clutch is a nismo one..i got the car at 60k miles and its an 05, perhaps it has been replaced
Watermelonwarrior
Car: 2006 Cayman S 6SPD
Dasoupdude wrote:hmm all i know is that when i first get in the car in the morning and drive down my neighborhood as i hit the clutch to go to second it makes this dread rattly sound, i wonder if my clutch is a nismo one..i got the car at 60k miles and its an 05, perhaps it has been replaced
ya my car does the same thing
dasoupdude
i die a little inside every time i hear it, even if it is normal
sliver
Car: 2003 350z
i die as well lol.
dasoupdude
lolz
Meng1988
Car: 1996 Nissan 240sx SE
If it is an unsprung disc then that is why. The springs in the disc help to damp torsional vibrations. But if you don't have the springs you will hear it. If this is the case, nothing is wrong.
Return to “350z / 370z Discussion”
