NISMO clutch pedal bracket, Any1 here actually install one?
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Anyone, anyone? Buellllllller?
Nismo400R33GTR
Car: 1991 240sx HB s13.5
i will be this weekend actually why whats the problem?
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
nothign is just that if you not lazy ad has a stock one you could probally do the same thing with a welder
elchoccolatte
Car: 2K3 2.5 SL Altima, 91 Nissan 240 Sx Se
:lol: :lol: :lol:
Dano
Nismo400R33GTR wrote:i will be this weekend actually why whats the problem?
chaosli wrote:nothign is just that if you not lazy ad has a stock one you could probally do the same thing with a welder
ACTUALLY, smartass, there is some issues. I bought this years ago, when west covina first made them availiable. At that point, nobody had installed them yet, we just knew they were NISMO, reinforced, and looked pretty, haha. Anyways, i'm rebuilding my car from the wreck and it's time to swap it in, but after I got into it, found some issues.
The clutch pedal was made specifically for RHD cars, so few things are different. The overall bracket and mounting is still the same but:
On the US piece, the return spring is mounted about an inch lower than the pedal lever hinge.
On the NISMO piece, the spring mounting holes are about 3" away. At first I thought the width was wider on the NISMO piece, but looking again I think my eyes deceived me and it's the same width between spring mounting holes.
I'm not sure if the JDM pieces, or nismo-specific pieces have a lever with the spring hook/seat mounted in a lower position on the lever, or if it's supposed to use a much bigger spring.
Also, the NSS arm on the US lever hits the NISMO bracket about 1/2 way returned. I don't use a NSS with my 5spd swap, so I could get by with just cutting that arm off.
Now I think I can just, as said before, cut the NSS arm off, and then I think I could just drill the holes for the US spring in the same spot as the US bracket and utilize it that way, I just wanted to see if anyone had figured out the parts to put it in as designed... I'll snap some pics later of what i'm talking about.
Nismo400R33GTR
i wasnt beeing a smart a** actually. but you didnt really post any sort of question to go off of other than if we have done it ya puts
Dano
I wasn't referring to you! :-P I was trying to answer your question, chas was being a smartass.
DuckyD
Car: 1995 240SX
We had a customer that kept popping the spot-welds that come on the stock clutch pedal bracket. We thought about ordering him the Nismo unit but realized beforehand it would be for RHD.
Instead, we reinforced his pedal by stich-welding the brackets (instead of the factory spot-welds) and he has not had a problem since.
Dano
Word, lots of people do that, but I already have this, so that's irrelevant, thanks for the info though!
Dano
Bump, I've just been lazy with the pics, maybe someone that has one will see this and chime in.
Dano
lksajk jdsflkdsjfl
DuckyD
Car: 1995 240SX
Dano wrote:lksajk jdsflkdsjfl
Why do you keep bumping this thread? You are the only one that cares...
DMan II-40
Car: 1995 240SX SE
Because he wants someone with a hands on experience with this product to chime in. Why does it bother you so much?
DuckyD
Car: 1995 240SX
DMan II-40 wrote:Why does it bother you so much?
It doesn't bother me.
I gave good insight and he called it "irrelevant".
It's just that any input into this thread has been met with hostility or dismissed by Dano.
Dano seems to think he has a way to make this brake pedal bracket work on LHD 240sx. But for a week he keeps saying that he will post pics and keeps bumping a thread with no new information. So what is the point?
Bottom line, the Nismo Brake Pedal Bracket is designed for the RHD 180sx/Silva. You might be able to use it on your LHD 240SX, but not without modification in which case it would have been more beneficial to simply use a stock bracket and modify that to make it stronger. Dano already said he figured it out "Now I think I can just, as said before, cut the NSS arm off, and then I think I could just drill the holes for the US spring in the same spot as the US bracket and utilize it that way, I just wanted to see if anyone had figured out the parts to put it in as designed... I'll snap some pics later of what i'm talking about."
That was a week ago.
