***NOT TRYING TO SELL PRODUCT JUST PROVIDING INFO. I'M NOT AN AMSOIL DEALER. SHARING A PRODUCT I REALLY LIKE****
AMSOIL filters are good filters and what I like even more is that they are dry filters, meaning you don't have to oil them and worry about messing up sensors because you accidentely added too much oil. They also last just as long as the KN filters and supposedly filter even better.
AMSOIL Ea Air Filters allow more airflow than filters that use cellulose media alone. Cellulose fibers are larger than nanofibers, and have larger spaces between the fibers, causing contaminants to load in the depth of the media and plug the airflow path, which results in higher restriction and less capacity. The synthetic nanofibers in EaA Filter media have submicron diameters and small interfiber spaces, which result in more contaminants being captured on the surface of the media and lower restriction.
AMSOIL Ea Air Filters hold up to two and a half times more contaminants than cellulose air filters. Since the nanofibers in the media are so small there are more pores per square inch, allowing for higher dirt-holding capacity and lower pressure drop when compared to cellulose filter media alone. Thinner media fibers produce more uniform pore size distribution, improving the filter’s overall quality and ability to capture and retain particles. Testing shows that Ea Air Filters hold 15 times more contaminants than a wet gauze type filter.
FRAM K&N AMSOIL Ea GM (OEM) Media Type Cellulose Wet Cotton Gauze Nanofiber Cellulose Retail Cost $24.95 $54.97 $38.10 $23.85 #of Changes/Cleanings(25k/yr) 1 Change 1 Cleaning 1 Cleaning 1 Change Cost for 4 Years $99.80 $74.92* $38.10 $95.40 Cost per Year $24.95 $18.73 $9.53 $23.85
* Plus additional purchase of cleaning and oiling kits
They also offer a pre filter sock to help protect from water and bigger debree. AMSOIL Ea Pre-Filters will not cause any significant reduction in air flow. In fact, AMSOIL EaAU and EaAR Filters allow more air flow than the engine can process, so adding an EaPF will not prevent a more-than-adequate amount of air flow from entering the engine. (
http://www.amsoil.com/storefront/eapf.aspx)
Link to AMSOIL for information on their induction intakes:
http://www.amsoil.com/storefront/eaau.aspx
Click on "See detailed EaAU specifications and photos (200k PDF)" to see pictures of the induction filters that they offer and the sizes they come in. It will also give you the size of the filter such as overall length width and inlet size.
Click on "EaAU Dimensional Measurement Features (37k PDF)" which will show you how they messure their filters so you can better understand what you're reading on the specifications page.
