NISMO CA18DET & SR20DE clutches
CA19DET
from looking at the NISMO catalog i see two interesting things,
the part numbers for the SR20DE and CA18DET clutch disks seem to be the same:-
SR20DE:Clutch Disc [Ceramics Metal A]P#: 30100-RS550Y= 28,650
Clutch Disc [Ceramics Metal B]P#: 30100-RS500Y= 28,650
Clutch CoverP#: 30210-RS526Y= 34,000
CA18DETClutch Disc [Ceramics Metal A]P#: 30100-RS550Y= 28,650
Clutch CoverP#: 30210-RS550Y= 27,580
(the clutch cover/presure plate is obviosly bigger for the SR and i think this was the problem with fitting the SR clutches on the CA.
and the second interesting thing is this
Big Operate Sylinder P#: 30620-RS520 Y=13,930for CA18DET, SR20DET [dia: 20.54mm (STD 19.05mm)] / can not fit with twin plate on CA18DET
- does this mean that NISMO makes a CA18DET twin plate clutch???
i am going to be using the 3 puck solid clutchmasters SR20DE disk that my friend has in that case for now, and upgrade to hopefully a twin disk when the engine is broken in and i begin to wind up the boost...
just exploring different clutch kits..
Clutchmasters actually says they have a twin disk set up for the CA that they say is good for 500hp = price $ 1500.00 (lonnie - [email protected])
and then there is always the magical exploding clutch from SPEC :D
CA19DET
HKS also makes a twin disk clutch
HKS GD Clutch Pro KitS13 (CA18DET) S type : Twin Push Y= 104,297
(getting all these prices and info from http://www.ooparts-international.co.jp)
CA18Fastback
hey, not all clutches from SPEC explode. i hope that was a very rare occasion because i have my SPEC Stage 3 and dont know if I can afford to buy a more expensive clutch any time soon. what should i do???
-Ian
CA19DET
keep an eye on your spec clutch and inspect and re-tourque it often to make sure it doesnt/isnt slipping and that the cover is securely fastened to the flywheel...
after seeing that stage 3 explode on that SR it scared me... i like my legs..
clutch masters also has a stage 4 for the CA18DET
Clutchmasters stage 4 kit part# 06-039-hdcb price$ 465.00
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
how much is the stage 4 clutchmasters kit good for?the price sounds good and i need a clutch but i cant afford to keep checking on it and making sure its all ok. i do that with enough parts on my car already. i was going to buy a spec but if its going to explode and damage stuff id much rather drop a small fortune in gold on a hks or nismo kit. some of those things have prices equivalent to the GNP of Samalia. its rediculous.
- tim
CA19DET
FX400 (Stage IV)
· Ultra heavy-duty street &racing system· Holding capacity 170% over stock· Heavy-Duty reinforced pressure plate· Hi-Leverage™ pressure ring design· Sprung hub/4-button· Ceramic friction material-------------------------------------------------------------------------------- All Clutch Masters systems come complete with: Pressure Plate Clutch Disc Throw-out Bearing Pilot Bearing or Bushing (when applicable) Alignment Tool
r34 gtr
looks pretty nice to me. ill be looking out for that when i get some money...whenever that is. 170% over stock should suffice since i dont plan on making gobs of power anythime soon. thanks!
- tim
jberg240
Car: cars
does anyone know where to get a good deal on the s-puck nismo clutch for sr20det?red top
drumma022
Well, i know for a fact that the OS Giken GTI-R twin plate clutch/flywheel combo works for the CA18 as well, you just need to make sure to get the correct Throw out bearing.
jberg240
Car: cars
All I need is a single plate. is the size the same(240mm)? Do you know where is the best place to order one?
quest
those pictures of the exploded spec sr clutch, posted on the net sure made alot of waves, but that is the only case I've seen. Are they more ? ...otherwise that would be suspect. I think Secret? or Enjuku used spec clutches on quite a few hopped up SRs without incident.
cuzano? is running/sells a $289? Hyperclutch on his moded ca18det. Thats one proven option there. Says other stages are available also.
Daikin is an oem supplier and offers various stages, but you gotta "nail down" the application for the ca.
You can also have a local clutch rebuilding shop beef up your oe one. Preety cheap and they have vast experience, so you'll end up with the "right" clutch for the job.
I've found 2 ca18det imported with a 3 puck sprung hub, metalic pad clutch disc with a stock looking pressure plate. What are these ?
CA19DET
Quote »I've found 2 ca18det imported with a 3 puck sprung hub, metalic pad clutch disc with a stock looking pressure plate. What are these ?[/quote]thats what mine came with, after getting it re=lined it slipped after a while and that was at stock boost, i am sure it was the tired cover/presure plate that was the cause..
i was thinking of just getting that clutch and cover rebuilt, but my builder says that most clutch manufacturere have better methods and materials to rebuild the clutches and presure plates you got to be carefull with at my HP level, but after seeing the SPEC unit and hearing that it was just a re-built OE clutch (in the SR case it was a re-built Z32 NA) makes em think.....
but i think i am going with the Clutch Masters.
no one seems to have the NISMO CA cover available... (but i think the NISMO KA cover si the same and if so courtesy Nissan may have them) but you still got to ge the correct disk,.
float_6969
Mine came with that same kinda clutch also. I think it looked like an HKS clutch. But mine had a bad rear main seal and had leaked oil on it, so it was shot. Oh well, minus the light clutch pressure, I'm VERY happy w/my Stage 3 SPEC clutch.
r34 gtr
http://164.46.112.185/NissanPa...s.htmim just so money. i think thats got what you wanted, right?
- tim
r34 gtr
or here http://www.uniqueautosports.co...e.htm
CA19DET
i've seen those palces before and actually emailed japanparts.com about getting the parts and they said they dont stock em so it'll take weeks to get here...
and well the other, have you ever tried to get parts from australia?? takes long, cost allot, and clutches are heavy!!!
r34 gtr
yes, i have gotten parts from australia. i try and get all the parts i possibly can from perfect run ( http://www.perfectrun.com.au ). i bought my hks intake from them and it was here in less than a week. they are overpriced on some things, but they are very helpful and have everything they have on their web page in stock at all times. unfortunately, they have nismo and cusco clutches for every car but ones with the ca18det.
- tim
CA19DET
here is the NISMO cover from http://www.courtesyparts.com a authorised NISMO dealer:
Code: 30210-RS600USPrice:$271.84
Genuine NISMO (Nissan Motorsports International) part.
240sx 1989-1998 Pressure: 750 kg
as you can see the part numbers are diffrernt between the CA and KA part numbers but supposidly they work.. i would love to speak to someone at courtesyparts.com to see if they have the CA cover or if infact that KA cover they have lsited is the correct thing just numbered different for US cars with the KA for stock and tracking reasons (which i believe it is)
demon
What are you guys planning on using for a flywheel with the single plate clutches?
CA19DET
unfortunately the stock flywheel...
getting a JUN flywheel will be expensive.
i am wondering if the GA or even SR fwd flywheels may work... or even the fwd KA flywheel.
CA19DET
CUSCO HEAVY DUTY CLUTCH PLATE & CLUTCH COVERDisk = 00C 022 C202N (Metal) A$422Cover = 00C 022 B006 A$439
looks like the disk that came with my CA, same colored springs in the disk......
demon
CA19DET wrote:unfortunately the stock flywheel...
Where are you guys sourcing the stock flywheel?
float_6969
Ditto, I think thats what was on mine...
r34 gtr
how well does that cusco clutch hold up? im about to do mine (christmas present) and i only want to do it once. im eventually going to be making horsepower in the upper 200s to lower 300s range and dont want it to slip on me under any circumstances. should i just go with a twin plate or will a good single hold it?
- tim
float_6969
My SPEC stage 3 is good to about 350ft/lbs or torque, wich would be close to 400hp with our motors. It's a 6 puck, sprung hub, single plate clutch.
Vetal
I couldn't find clutches for CA18DET on clutchmasters.com...
Xero
get a ORC and you get both the clutch and flywheel :D This is what I'd run for more than 300hp,
Vetal
How much? :)
Xero
hahaha, well, a little more than getting everything seperate, I think they go for a little over a grand. Imagine 350-400 for clutch and 550 for a flywheel.
Vetal
Huh... Only 2 my month salaries :)))
