chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Wed Apr 14, 2004 8:30 pm
nope. the point of a larger rotor is that there is more material to absorb heat, and drilling/slotting only removes material, lessening their ability to absorb heat, as well as weakening the rotor. drilling the rotor is from back in the days when organic brake compounds were used, and they create gas which needed somwhere to go, hence the drilling. Now in the days of metallic and semimetallic brake pad compounds, no gas is created which makes drilling worthless. Slotting rotors does not weaken the rotor nearly as much as crossdrilled, and less material is removed, I dont mind slotted rotors as much. I know rally cars use them to keep the pads clean of dirt and snow and such, so i could see a use for this if you live in an environment like that. but you shouldnt be trying to race a 240 in the snow or mud or whatever anyway.
please noone say that porsche uses cross drilled rotors so it must be good; they use it because they have completly different materials in their braking systems and it is not nearly as detrimental. Porsche themselves has stated that the cross drilled rotors are only to provide a sporty look and increase initial wet braking.
but dont take my word for it, do your own research.
