sldwys »
https://forums.nicoclub.com/sldwys-u65477.html
Mon Jun 08, 2009 10:59 am
nope, The Flange size is the same as Rb26 Genuine therefore you can use rb26 genuins gasket.
see below
Kit ■S13 sill beer RS180SXCA18S12SR20 - Yahoo! Auction
Commodity explanation
The NISMO 4 connected throttle kit @ commodity explanation for @ CA18 It is the [nisumo] multiple throttle kit for CA18
Picture sort of viewing as for relatively state well Both the linkage & the throttle butterfly it works smoothly
Removal genuine surge tank of S13 type CA18 They are 4 connected throttle kits which can be installed in the genuine intake manifold
Stock it had done in one for NA [chiyun] of the multiple throttle of CA18, but There is no opportunity which you use
As for constitution of exhibition commodity
- NISMO private molding IN [mani]
- NISMO 45 pie throttle (2 machines)
- NISMO private throttle linkage
- Throttle position sensor
It becomes the above-mentioned contents
Perhaps now presently as for procuring 4 connected slot kits of NISMO Very you think that it is difficult, The throttle drum has not belonged, but D because type shaft type is installation possible, diverting, please install
In addition as for throttle gasket throttle body - volt/bolt span Because it is the same as RB26 GTR genuine throttle size, you can install one for RB26
If it makes multiple throttle specification, response rise and efficiency become good not to be wrong If NA [chiyun] of 4 connected throttle specifications and you can install the surge tank well You think that it is good to also [tabochiyun] and the like of 4 connected throttle specifications,
The intake manifold port part is not ground mischievously, Because to be light only stepped processing it has done Adjusting to the taste, you think that port processing and the like it is possible, In regard to viewing we ask the picture may concerning details
