lol joey those ADR's look better on your ride then they ever did on mine. just a few more parts and the car will be ready to take back into the hills86silvia wrote:so i'm assuming this should fit other r200 diff's. lets say one from a 1987 nissan 200sx S12?
thats what i was told cause i have an open diff....still havent installed it yetRobMc wrote:What about output shafts? Do you use the open diff output shafts or do we have to cut them or anything? If this is a direct bolt in affair into an S13 open diff then I will buy one right now.
hmmm i wonder instead of chopping the shafts if its possible to purchase the right ones?? i wonder if they will bolt upRobMc wrote:Talked to Travis via AIM yesterday, also conversed with Matt who is very knowledgeable when it comes to these things. You DO have to modify the output shafts of the open diff by cutting them about 8mm shorter. Travis is looking into what other (if any) mods will be necessary to install this into an s13 open diff. It's still one smoking deal and I'm going to buy one immediately.
Rob
if your findings will someone with an open diff need anything else besides the output shafts?? If not I am calling dibs on yours99maxgtr wrote:ok well i've been reading up on output shafts and what not and i am pretty sure that j30 as well as 240sx with vlsd output shafts will work. now if this is the case i am selling my vlsd output shafts if anyone is interested. 130 shipped or best offer. these are the 6 bolt configuration 3x2.
No it will not without modification. I found that out and called to cancel my order.hybrid_flyer wrote:so stanley the nismo will not fit open pumpkins at all???
