Nis. Maxima with Polk Momo
Post all your Nissan electronics, car audio and stereo questions here!
SinfulDays
Car: Nissan Maxima Se
is there any maxima owners with polk momo install.. if so can i see a picture of your set up..door panels. was there any adjustments
i just purchase polk momo 6500 and 5250 they have a sale going on buy one pair 2nd pair half off.. i just want to see picture of vechiles with the set up...thanks
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
What year maxima do you have? For the most part you should be able to fit everything under the stock grills. From what I remember the tweeter cups are kind of big but if you have black door panels or factory tweeter locations you shouldn't have a problem. Oh almost forgot they are pretty deep and may need spacers but the magnet covers also come off if just a little more will make a difference.
SinfulDays
2002 max with bose system
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Everything should install under the factory panels except for the rear tweeters, so outwardly you wouldn't notice anything different. In the back I'd keep the tweeters mounted down low so they won't distract from the front imaging.
SinfulDays
do you have similar set up>?
audtatious
It's not Polk but it is the factory location...
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
SinfulDays wrote:do you have similar set up>?
I have a makeshift component setup for my car. I was an installer for a long time and worked with a lot of the Polk stuff.
SinfulDays
cool thanks.. i'm not an installer thats why i ask.. rear installation sounds little work..
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Not too bad but yeah a little more work. I don't know if you can bring the 5250's back and get a set of 650's because it will be less work and sound just as good because the rear separates won't make a huge difference anyway.
SinfulDays
i order from crutchfield. i enter my car information.. and it says that 6500 will not fit the rear only the front.. so that is why i went with those. they were the same price
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
6.5's will fit back there. The main point though was to return the component set and get the equivalent coaxial set for the rear to make install easier. You wouldn't even notice a difference in sound quality.
SinfulDays
least the offer free return and shouldn't be a problem having it exchange.. i might even have it tomorrow.. or friday its already in ca.
SinfulDays
got the rear installed except for the tweeters need a hole saw to drill on the panel..
for the front should i put the new tweeters where the old tweeters are located or should i have them on the door panel..
i kinda want it on the panel but if it can fit where the stock tweeters located then cool
