mac, Let's see carb adj (inside to out) = Float level ,jets , metering rod (springs/depth) +vacumm/power pistons ,linkage -WOT +"idle stop" , accelerator pump -start/stroke/duration , Choke , finally Idle mixture screws.Gotta know if screws are a FUEL or AIR adj = most important!
Are you talking mixture screws for Idle/off idle ONLY or are they in the power ckt. , like an external float adj (similar to holly) . I'm going with general SOP here , without taking apart , and if screws are for idle adj. - I don't believe externally your going to affect A/F much to show in plugs unless ,you can first "mess" with the power enrichment(rods ,piston,springs) from outside , or bigger factor is float level -and if that is an external adj. I mean also ,I don't know if you DID a full rebuild , but my point is pulling plugs to gauge things often - your (definately ) not dis-assembling carb, nor WANTING to every time! Although 40 years ago I had Mopar THERMOQUAD , so easy to work , take apart , adjust (maybe me?) , had the energy back then
Keep in mind EVERYTHING comes "OFF" the float level , JETS next,then power enrichment(rods) , LASTLY idle screw adj.
All that being (generally) in order of performance MAGNITUDE ,say. Remember - power enrichment generally leans out with steady cruise , then when you "mash" - on up to WOT it's ALL a function of Jet size (w/without rods) in conjunction with where your float is set.
