NICO's official 4 port pic thread!
float_6969
Post your pics of your 4 port head and the work you've done to it. I'll start with my un-modified head.
Image Image Image Image Image Image
tommey
Car: S13 ca18det
boost_boy
:wtf2: Wicked :naughty:
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
what the hell are you doing to that head???
float_6969
Cutting it up to see where the coolant/oil passages are so that when you start doing port work on another head, you know how much material you can remove.
tommey
Car: S13 ca18det
float_6969 wrote:Cutting it up to see where the coolant/oil passages are so that when you start doing port work on another head, you know how much material you can remove.
Yes, it can be used for that purpose too, but i just wanted the flanges.
Valvebounce
Car: Datsun 1200, Datsun 510, NIssan WGC34 Stagea, Datsun Sunny PB310
Here is mine.
Nuff said.
tommey
Car: S13 ca18det
Exhaust valve seat opened up 1mm
float_6969
The un-modified head I posted earlier with it's current gasket match, polishing, 4 angle grind on the exhaust port with back cut valve, and radius cut on the intake ports and back cut valves.
