elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun May 01, 2011 6:31 pm
Seems weird that this would happen.. Electronics don't normally "go bad" like this, and I've certainly not seen anything like this..
My first thing I would look at is open the ECU up and make sure that the circuit board is fully seated onto the socket... on the 4 way ECU I have in my car the switch actually went bad on me causing it to intermittently stall, and thats an easy fix..
If you want, you could send it to us and we'll take a look at it.. We would be able to determine if its the ECU itself thats messed up, or the upgraded chip thats the issue.. IF the ECU is bad, then you could easily install a new socket into your OEM ECU and you'd be back in business.. Shoot me an email off the board and we'll get you fixed up!
