audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sun Dec 07, 2008 8:23 am
Doing a google search for firefox crash I see numerous issues regarding FF, add-ons, Java and Flash. While NICO itself is not coded with flash, some of the AD's are flash. Below was a "fix" for someone having similar problems while using youtube:I just had this problem 10 minutes ago. Solved it with this info:
1. Browse to C:\Documents and Settings\<username>\Application Data\Macromedia\Flash Player\#SharedObjects\GVP000012. Delete all the files and folders in this folder3. Browse to C:\Documents and Settings\<username>\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys4. Delete all the files and folders in the directory5. Restart Firefox, you should not need to restart your PC
And then:
1. Go to tools -> add-ons -> plugins2. disable flash plugin3. refresh youtube webpage4. go back to tools -> add-ons -> plugins and enable flash plugin5. refresh the youtube webpage....it should work now.
