Good to know. I think I'm running stage II (whatever the one is that's fairly safe) and haven't switched it for months...3Q Jay wrote:Bowen originally recommended to turn the car off, or at least go to idle before switching programs.
How did you make out Andy?mxr662 wrote:So I think I'm ready to install my Nico ECU
The small wires connect together to switch from stage II to Stage III?Can you switch with the car running?
I plan on unhooking the battery. Then carefully installing the ECU. Anything else?
Andy
Push on push off will work. Momentary contact is only closed while holding the button.Haitian_King wrote: I wired a small push button momentary switch from Radio Shack. Just a small black switch with a red button. When it's depressed, the ECU should be on, when it's in the off position, the program should be off. I haven't tested it yet though.
A little scared to. Maybe when it comes back from the shop and I don't have to worry about the engine.mxr662 wrote:
Reji-- just install the ECU- its cool with the stage II program
Andy
Tech, how do I select the proper A/F and advance? Through Nissan DataScan? Like if was to get the Blazt kit setup? A friend of mine mentioned something about his ability to "tune" my Q from his laptop, but I wasn't ready to let him.Q45tech wrote:I've used the Dinan equivalent {fixed not adjustable} of Stage 2 for the past 15 years, same with JWT trimode TCU been in 1st gear- high shift for 2 months less, it has seen service in 3 different trannies [180k in #2].
Select the proper A/F and advance and don't worry about it.
