Nice brake combo...
Julio Bro!
Car: 1993 240SX SE, manual transmission, Stillen intake & strut bar, Magnaflow cat + custom cat-back, NISMO sus
For those of you looking to moderately upgrade the OEM brake system, at NOPI you can get Brembo slotted rotors and Australian ceramic pads.
The Brembos are less expensive than the Power Slots, although sold in pairs. And, besides being genuine Brembos, they seem to have more slots than the Power ones.
The kevlar-ceramic-metal pads are Australian made AXXIS ULTIMATE which are wider than other performance pads (like Rotex); this means more contact area which should make for better braking and uniform wear of the rotor. I also noticed they have a built-in anti-vibration backing.
Good bang for your buck.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
so i assume this setup is on your car? do you have any problems with braking when the brakes arent warmed up all the way?
Chingon
Car: 1991 and 1992 hatchbacks
i have the ultimates. They dust quite a bit, but it's easy to clean. They are quiet though, and have nice bite.
Julio Bro!
Ender_Zero wrote:so i assume this setup is on your car? do you have any problems with braking when the brakes arent warmed up all the way?
I've had no problems at any time, up to now the setup is the same or better than with the Rotex pads. The only thing is a bit more dust, as Chingon says; Rotex are cleaner. But for the casual racer, I'll say these are much better.
When these wear down, I'll probably switch to the Kevlar-Metallic type because of the dust...but I'll take them from NOPI too...better priced.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
NOPI sells the Brembo blank replacements for $25 USD if you guys want the replacemnts
slipnfall
Car: '06 D40
Is that right, $25? Are they genuine Brembo? Any anti-rust coatings available? HeavyThrottle want's $64.50/ea, drilled,slotted,cadmium silver coated. Are Brembo's at *least* as good as OEM? 'cuz those are around $65 ea. Since I'm looking to buy the blanks, if they aren't much better, I'd rather have OEM.
Thanks for the suggestion Julio.-Jamie
slipnfall
Car: '06 D40
Just checked NOPI's site: they're $28.41...Not bad, thanks. Do you think they'd hold up as well as OEM? Daily driver, no track or autox, just hard street driving.
-Jamie
eddiec
Car: 91 S13
ive had brembo blanks from the tirerack and have no issues. the fronts are squeezed by ebc greenstuffs and the rear are warmed over by hawk hps pads.
no warpage and this is on an a/x car that is not street driven.
i also use ate blue and ss lines.
sean8564
1993 Nissan Silvia
slipnfall wrote:Just checked NOPI's site: they're $28.41...Not bad, thanks. Do you think they'd hold up as well as OEM? Daily driver, no track or autox, just hard street driving.
-Jamie
No problem My buddy has them on his WRX and he is one of the hardest drivers I have seen and they have no problems in the 8 mos. he has had them.
Julio Bro!
slipnfall wrote:Is that right, $25? Are they genuine Brembo? Any anti-rust coatings available? HeavyThrottle want's $64.50/ea, drilled,slotted,cadmium silver coated. Are Brembo's at *least* as good as OEM? 'cuz those are around $65 ea. Since I'm looking to buy the blanks, if they aren't much better, I'd rather have OEM.
Yes, these are better because of the cooling/cleaning slots, they are original Brembos (used on sport and super sport cars), and they cost less than Nissan rotors. Any other OEM style rotors won't perform like these, I've run them hard and no fade or warp.
