Nice 300ZX Brake Upgrade - Can we use it on our Q's?
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Take a look at this upgrade for the 300ZX.
It appears to be a prety good deal.
Especially, if It will work on the Q45.
http://www.arizonazcar.com/300zxbrakes.html
90Q45blue
Car: 2006 Honda Accord EX-L
I wonder if we could use the cross-drilled, slotted rotors from Stillen or BRM with those brakes. If so, I'd see if I could just buy the calipers, hardware and brackets. Hmmm.....wheels turning.
Nick
MiniMan
The chap Rob found the 14" big brake kit through before also made up a 13" kit for the fronts and I'm sure could supply for the rear too.
IMO, I quite like Rob's idea of doing the 14" 6 piston setup up front and swapping the front's to the rear with better rotors. Slightly over $2k total, or $1800 just for the front. As with the kit you mention though Jeff, you'd still need to fabricate your own mounting brackets.
Corey
1992Q45A
Jeff,
That kit is from WILWOOD. WILWOOD HAS A KIT FOR THE Q45.
If you are going to purchase a Wilwood kit, you may as well get the one SPECIFICALLY MADE FOR THE Q45.
