245 is WAYYYYY to wide for a 7inch wheel... a perfect fitment would be 215 but the next size up would be 225Apexi wrote:Whats the next tire step down from 245/45/17 on a 17x7 rim? I've been searching for ever and cant find anything! Thanks!
Well right now I have about a 1.5" front and maybe 1.3" in rear.240sxjeff wrote:Yeah 245-40 would be about the same size as your stock wheel/tire combo.You can also go 235-40 which has a little less sidewall(barely) and is about 10mm smaller in width.The way I look at it is by how much fender clearance I have, I put 235-40 on my 17x9's and it fits perfectly with a minor roll and about 2.5 in drop. Also the 235-40 will give you a slight stretch but nothing major.
Aww then 235/45 is what I'm looking for! Thanks nismofly, you rock BTW Will I have any problems or need to do any work to make them fit? I dont want to roll fenders right away....nismofly wrote:the sidewall height is larger on the 235/45
the 245 only looks like it does because its less stretched
