Sorry, totally not paying attention. Well, I would go component for the fronts (6.5 in the doors and tweeter up front - which would not be 3.5 inches, probably closer to 1-1.5). So you would only need a two channel amp for the fronts. If you're concerned with adding rear speakers later, it would be worth going with a four channel amp now so all you need to do later is install rear speakers (unless you decide to leave the rears out). If you go two channel now and leave the rears out but decide to later add rear speakers, you'd need to get another amp. That is the dilemma. Give me a figure of about what you're thinking to spend and I'll see if I can come up with some good recommendations.ADKSaad1387 wrote:bump applebonker or doc?
ADKSaad1387 wrote:that model is from 2 generations ago, and its a punch amp... I'd go with the Rockford Power amps (T-400-4 or T600-4) and stay away from the punch amps.. not that the punch amps are bad, they just aren't as efficient or powerful as the Power AmpsAppleBonker wrote:Sorry, totally not paying attention. QUOTE]
No big haha your the one helping me so i cant ask of too much
but that sounds like a good solution. I think i want to leave my options for the rear speakers open and get a multi channel amp. that way down the road im not stuck with getting ANOTHER amp. the big dillema is the money now. I wasn't expecting to have to get another amp and the multi-channel amps are gonna get expensive.
I just went to crutchfield.com and looked at amplifiers. the first one i saw was a "budget friendly AND its RF . http://www.crutchfield.com/App...p=115 .... what do you think?
