next power upgrade
luis741953
Car: 1995 nissan 240sx se
hey guys i wanna get your opinion on what my next power upgrade should be please give me some ideas
i have a s14 blacktop stock turbogreddy FMICApexi Avc RApexi Power FCApexi power intake3' full exhaust
TchouikoS13
Car: 92 240sx HB + 06 Porsche Boxster S(vert)
With the turbo you need a lot more parts then just the turbo.
cheapscheisst
Car: 1996 240sx w/ Kouki front end
gt2871 w/stock injectors... haha. your gonna want 720's for that turbo. you'll max out the 550's.
luv2spedup
Car: 89 silvia
cheapscheisst wrote:gt2871 w/stock injectors... haha. your gonna want 720's for that turbo. you'll max out the 550's.
yep... may be you should just get some injector and crank the boost up
theclub
Your stock tubo is good, put the power you already have to the ground.
Morph
Car: 91 Sr Powered Coupe
I added s15 turbo just incase you got the non bb turbo on there. Not that much of an increase but quicker spool and newer. Might help.
chicos240
Car: 1995 240 SX
theclub wrote:Your stock tubo is good, put the power you already have to the ground.
The better you hook the more efficiently you will use your power. More power is useless if you can use it where it counts, at the wheels!. Not only that but if you use lighter components and a better lsd you will notice the difference in the way your rpms move and the way you car handles.
luis741953
i forgot camshaft, valves springs and retainers, i know ill need bigger injectors, fuel pressure regulator kit and upgrade my intercooler to spec v or spec r?? (im not sure about this one) what else do u think i need??
Morph
luis741953 wrote:i forgot camshaft, valves springs and retainers, i know ill need bigger injectors, fuel pressure regulator kit and upgrade my intercooler to spec v or spec r?? (im not sure about this one) what else do u think i need??
What kind of numbers are you going for? Depending on what greddy IC you have and the numbers you want the one you have could work.
luis741953
im going for high 300's or low 400's hp
TchouikoS13
If you want those numbers, you need the gt28. Along with a bunch of other parts to accompany that.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Be better off using the GT3071R for 400+whp numbers. Theres very few that have made 400whp with the 2871R. Typical numbers are around 365-385whp.
