newly swapped SR cranks but won't turn over
AllTurBo
Car: 94 red drop top w/SR
Me and some friends were putting the finishing touches on my SR swap today. after we got it all together and the moment of truth came, I turned the key and the motor will not turn over. It cranks and at times it seems like it wants to fire up, but it mostly just cranks.
My fuel rail was bent when they pulled the motor in Japan, and when I crank it the seal blows out on the #3 cylinder injector. I knew the fuel rail was going to be a possible problem, and now I know that I need a new fuel rail, but I the car should still at least start, right?
There is definitley fuel still going through the other injectors, and I am getting sparks in the coilpacks on all 4 cylinders. I shocked myself numerous times trying to determine this.
Mo was helping me, and we had his s13 SR as a reference, so I know that all of the vaccum lines and hoses and stuff are in the right spot, and that all of the major stuff is in the right way. I am thinking that it's just something small and stupid that we forgot to do, but we just can't figure it out.
I am not sure what to do, or even what else to do to try and trouble shoot. I know it's getting fuel, I can smell it. And I know it's getting a spark because when I sprayed some starting fluid in there, it backfired out the throttle body. and I know it's getting air, because I'm still breathing.
Any Suggestion, besides making this post shorter
240_Keyy
Car: '90 240 Fastback
hmmmm, timing maybe? Mine did basically the same thing, it sounded like it wanted to start, but it never did. As it turns out, the fuel pump fuse was blown and the fuel lines were crossed. My motor smelled like it had fuel, but apparently it did not...
check that...
AllTurBo
the fuel is hooked up the right way, I checked it to another SR that was parked next to it. I am going to do the timing tomorrow, I think (hope) that is probably what it is. it was probably messed up from doing my metal head gaskett
Now I all I need to find is a stock fuel rail. Anyone know where I can get one?
does anyone who upgraded to top-feeds have a stock S13 SR fuel rail?
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Putting a car's valve timing 180 degrees off does the same things described.
S13240
You probably have some sort of internal problem like your camshaft lobes not set correctly to a certain degree or not getting enough fuel because of your bent fuel rail. Try checking for error codes too.
Nils
Car: road racing
curious to know what your solution was or if you have fixed the problem.. keep us updated.
n
Cyberkreig
Car: 1993 Nissan 240SX SR
$5 that i cant afford to lose says that its either A) Wrong ECU. B) CAS at 180*
Nils
Car: road racing
Cyberkreig wrote:$5 that i cant afford to lose says that its either A) Wrong ECU. B) CAS at 180*
true.. maybe he is running a type X ecu on a non type X harness/engine
we all know I had that problem and the symptoms are similar.
n
AllTurBo
I couldn't work on it today because it was raining. I ordered a new fuel rail and got it shipped next day, so once it get's here i'll slap it in and work on the timing. I have convinced myself that the timing is off, the way it sounds when it cranks leads me to belive that. 180 degrees off could explain the backfire out the throttle body. The engine is a type-X and I have the correct ECU/harness I made sure of that.
Looks like it's gonna rain here on the East Coast for the next few days, but i'll def. keep everyone posted when I figure out what the deal is.
Nils, you were only getting spark to one cyl. when you had the wrong ECU right? I am definitley getting sparks to all 4. my ECU is an E5
Cliff
AllTurBo
ok, well I replaced the fuel rail, and flipped the CAS 180*. Still no luck. It just cranks but will not turn over. I remember reading somwhere that it is sometimes necessary to reset the ECU, how do I do that? I am running out of ideas, I don't know what the problem is with this thing.
martin
You shouldn't just "flip the CAS 180 degrees", what you need to od is make sure it's set right, and that the cams(both oft them) are timed right. To check the cams you'll need to pull the rocker cover, crank it over slowely until the shiny links on the timing chain line up with the mark son teh cams gears, and #1 piston is at TDC, on compression stroke. Then you need to set the CAS right. If all of these things aren't right then it won't start. You alos risk bending valves if the cam timing is off by much.
My guess is that when you did teh head gasket the timing chain slipped a tooth or two on the crank pully so when you put it back together the CAM timing is off.
I hope this helps
-Martin.
AllTurBo
flipping the CAS was just a shot in the dark. If the cams were aligned right and the CAS was off by 180, then that would have fixed the problem. But, since it did not work I took off my valve cover and found out that the cams are indeed off. The guy who did my head gasket told me specificaly that it was timed right, so I took his word for it, but I guess he was wrong. He is going to come by later this week and do it. I hope that's the only problem.
Vrtgrumpy
Fix the fuel rail!!!!!!!!!! Then make sure the fuel lines are hooked up correctly... if no start make sure there is spark to the All the plugs. Then you can check the CAS timing. some clips/set have been coming with DE computers what # is yours???
AllTurBo
AllTurBo wrote:Nils, you were only getting spark to one cyl. when you had the wrong ECU right? I am definitley getting sparks to all 4. my ECU is an E5
AllTurBo wrote:ok, well I replaced the fuel rail, and flipped the CAS 180*.
AllTurBo wrote:There is definitley fuel still going through the other injectors, and I am getting sparks in the coilpacks on all 4 cylinders. I shocked myself numerous times trying to determine this.
riiiiight
AllTurBo
:ylsuper it was the timing, I messed around with it a bit and she fired right up. this rules:ylsuper
btw, the guy who put my head gaskett on totally disreguarded the shiny links and just threw the chain back on there. I had to shine a light down #1 cyl to find TDC, and looked at the cams to see if the marks were at 10 and 12. my timing is still probably a bit off, I don't have a gun. but she idols like a dream, purrs like a kitten.
Nils
Car: road racing
lol.. sorry to miss all the posts... Nico just alerted me of your posts.
Congrats on getting the car running.. good shizz =)
n
btw - yeah, you were right.. I only got spark on one cylinder.
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
congrats man, great to hear, now go take her out, stretch her legs and get back here and brag how fast she is!!!!
