Newly Swapped RB25DET Problems
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
So i got my RB swap done on Wednesday and been working out some small kinks on it. Heres a list of some issues im having that im not sure how to work out. Engine is a RB25 S1
1) Car starts up and idles fine when its cold but after its warmed up and i shut the car off, i have to sometimes give it some gas to get it to start again. Timing is at 15* and fuel pressure is at 43psi. I havnt converted my tach over yet but its reading a touch over 1000rpm which should be around 700-750rpm. Also something that might relate is that when i do get it started again, the idle bounces a little till i drive it some. Only bounces from 1100-1500rpm on my tach. Any idea whats causing this?
2) When the car warms up and comes down to normal idle there is a squeeking noise coming from the front cover. Its got a new timing belt, tensior, and idler on. When you rev the engine the squeek goes away. Any idea what this might be? *Just noticed after you drive it the noise goes away entirely till you start the car again*
3) My check engine light is on but it has a wierd pattern to it. When im applying throttle the light has a steady blink then when i let off the gas the light just stays on solid. I went to do a diagnostic test of the ecu but my ecu doesnt have the red LED to light up. Is there a diagnostic port somewhere (95 S14)? Also why do you think the engine light is coming on in this wierd pattern?
Modified by DrifterProdigy85 at 5:03 PM 6/7/2009
DrifterProdigy85
neonbomb
My rb25 does the same squeeking noise in your first video.
Mine isnt as loud but it started right after my new timing belt/idler/tensioner install. I hope we get some answers other than "its a new belt".
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Don't know about the squeaking noise but I hard wired my consult port from my ecr33 front clip. It's really easy and works just fine. There is a wiring diagram somewhere on the internet.With your fuel pressure, what psi did you set it to with vac off?With a new setup, checking for boost leaks is a must.
DrifterProdigy85
43psi w/o vacuum.
My tach signal seems a little funny too. Like on the uncalibrated tach, when it gets near 6k+rpm the rpm just wants to stop even though the engine is still revving. Whats this sound like?
matafied
Car: 1989 240 rb25det 1992 240 rb25det
belt sounds like its a little to tight
Neejay
DrifterProdigy85 wrote:1) Car starts up and idles fine when its cold but after its warmed up and i shut the car off, i have to sometimes give it some gas to get it to start again. Timing is at 15* and fuel pressure is at 43psi. I havnt converted my tach over yet but its reading a touch over 1000rpm which should be around 700-750rpm. Also something that might relate is that when i do get it started again, the idle bounces a little till i drive it some. Only bounces from 1100-1500rpm on my tach. Any idea whats causing this?
OMG I HAVE THESE EXACT SAME PROBLEMS!
#1 - I'm thinking it has something to do with the ECU temp sensor. When I unplug mine, there is no change in the idle. This is even after I replaced it with the CORRECT Z32 one. I think there's something wrong with my wiring.
#2 - Although mine does it a lot less than yours, I thought this may be due to my harmonic balancer wobbling a bit. I never really found out why it does that.
DrifterProdigy85
My coolant temp sensor is stock rb25 as far as i know and my wiring was done by Mckinney. This could be a possibility. My temp gauge never goes above 1/4 way.
neonbomb
Neejay i saw you posted in Zerolifts thread the other day on zilvia. Please dont buy mounts from those f***wads. They are such newbs id love to see their company get shut down
But back on topic.
Matafied I hope you are correct and I hope it goes away after the belt gets a bit worn
neonbomb
Any other opinions on the belt sound?
DrifterProdigy85
I dont know. Im thinking maybe i should have oiled up the tensioner and guide a little before putting it on. Its not a big deal as of right now.
Im trying to figure out why my check engine light keeps going on and off. Its doing it when idling now. I might just pull the damn light from the cluster. It runs fine but has a bad miss above 5500rpm under boost. Its got all new plugs and i cleaned all the springs and contacts of the coil packs. I think im gonna sauder a led on the ECU and see what codes come up.
Modified by DrifterProdigy85 at 10:06 PM 6/10/2009
