Jerid »
https://forums.nicoclub.com/jerid-u139271.html
Mon Aug 03, 2009 5:19 pm
Okay, I am now a happy owner of a 93' Hatchback. Stock everything, and coffee stained interior. I picked the car up in Houston yesterday, and drove it all the way back to Dallas. The shocks/struts are in HORRIBLE condition, but I already have an idea of the suspension I want (Tein springs, KYB shocks/struts, camber kit)(suggestions on where to buy would be helpful).
1.) I was really excited & worked up after that long drive, and forgot to check the oil before I made my way back home. I took the car to work this morning to clean it up (I am a PDI Tech at a Honda dealership), and remembered to look at the ole' dipstick. Wiped it off, and poked her back in..pulled it out & WHAM! No oil. Just so happens that after I started it back up & heard a clanking noise coming from the motor. s***!! I pulled the valve cover off, and the guard thing that goes above the timing chain was broke. I removed this, and put the valve cover back on, but it still sounds like the chain is rattling a little. Hopefully nothing else is broken. What is that guard thing called? Will it hurt to drive without it?
2.) I was doing about 90, and shifted into neutral, and as soon as I pressed the brake, 3 lights came on. (Check engine, oil, and brake) As soon as I put it in gear, they shut off. It did this one more time, for a total of two times. Any ideas?
Pr0n!!
Modified by Jerid at 8:27 PM 8/3/2009
Modified by Jerid at 8:29 PM 8/3/2009
