is this in the same spot as the tire size information? Also could this be another way to check your date? If you look at different Versa's they have 2 different battery tie downs. Example:Ever Victorious wrote:That's a good question. I got my manufacture date off a plate on my driver's door sill. I don't know about canada.
My vehicle ID is just to the right of the tire pressure sticker on the inside of the door post. You really havta look for it.CodeRed wrote: also the only sticker i have is the tire pressure and tire size sticker? Modified by CodeRed at 10:08 AM 6/2/2007
oh..good information, i wonder why they did it this wayscott@westcovinanissan wrote:there are two different battery tie downs one for the 6sp and AT'S (2nd pic) AND the other for CVT (1st pic)
they did that because the CVT uses a different battery then the 6sp and ATs.CodeRed wrote: oh..good information, i wonder why they did it this way
group size: CVT- 51R 6sp/AT- 35
here is an image of where it is, took me a while to find alsoEver Victorious wrote:For those who have not been able to find the production date sticker, it's where it should be but a slightly odd place.
You see where your tire inflation sticker is inside the driver's door? Follow that piece of metal towards the exterior, and look just inside the front edge of the REAR door. It is on the B-pillar's exterior, partially hidden by the rear door.
No, it's in the same place on the Canadian Versa's. Look more to the outside of the car on the door post and you will find it.ThirstyRoss wrote:
What am I missing? (canadian versa if it's different here?)
