Newer Pathfinder opinions
Micallen
Car: 2003 Nissan Pathfinder SE 4x4 V6
How many of you have moved on from an R50 to a newer Pathfinder? I'm considering a newer 3rd Gen Pathfinder (2010-2012), or a Frontier (roughly 2010-2016). What are your thoughts? Pros/Cons?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The R51's are pretty bulletproof except for the well-known problems with the timing chains, timing cover gaskets, transmission cooler intermix, and crumbly heater water manifold. If you find an '11~12 the timing chains and cooler were both fixed already. The D40 Frontiers with VQ40 engines were a subset of the R51 design, so if you stick to '11-up it's the same deal.
Micallen
What about 11-15 Xterra? (if I can find one)
And why are so many of them red?
VStar650CL
Technical Expert
Micallen wrote:
Mon Mar 04, 2024 8:50 am
Nothing wrong with that, the N50 is just another derivative with the same hardware.
:biggrin:
I honestly don't know. The sapphire blue ones are plain gorgeous, but I think I've only ever seen two of them. You're right, the red ones are all over the place.
:confused:
