Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Apr 28, 2004 11:27 am
The original wheels are 6.5" (you have to measure the wheel, with the tire off. It is from inside bead edge toinside bead edge.
8.5" wheels all the way around would be tight, on the front. I have 8" on the front (17" aftermarket), and they fit fine.
Any bar made for the 00 Maxima will work, if you don't mind doing a little drilling. make sure the plate that the strut bolts go through is flat, and not ridged.
I agree, on the brakes. Look at AZhitman's thread about the stainless steel lines, fluid, etc. This helped my brake pedal feel tremendously.
I plan on a 300ZX aluminum caliper upgrade soon (Unsprung weight, etc). I have been searching eBay for a cheap set. I already have the cross-drilled and slotted rotors (they eat up brake pads). Next time, I will go for cross drilled, only.
Be careful buying old used wheels. They will more than likely be out of round, and warped. Not many 300ZX drivers were easy on the wheels.
