newby ?'s
JoeKart
Car: 240sx (180sx)
ok i have a 90 240sx w/ ka24eorginaly i wanted to just swap for a k24de then boost down the road but in thinking about it more i am starting to lean twards the thought of a ca18det they can be had where i am at a decent price what i was thinking though was if i build a ka to boost the buy a turbo kit i would have spent a good deal of money over $5k i was guesstamatingbut a ca motor new turbo and supporting mods would be much less close to 3k guesstamate agianwhat would you do?i havent decided yet so i wanted to see what others would do
sr20 is not an option
asher4857
Car: '89 240SX Fastback
its all really about what you want.
personally, i didnt want to have to deal with having to rebuilt my KA. So i went CA. it was an engine that was turboed stock so i know for sure it can handle boost. id say the ka when boosted would have much more torque especially the KAE
I still like to think of my CA as a mini RB heheh
89'ClubK's
Car: 89' Nissan 240SX
You can boost the KA and it might last forever, or it could last a day.Same goes for the CA. If you can get one locally, check it over very carefully.You can buy a bad one for the same price as a good one. It's the luck of the draw. Either engine will need to be "freshend up" in order to be reliable. Ask yourself which route you want to go- JDM or USDM ? or do you just want whatever gives you more power.It is the same hassle w/ the harness & power steering w/ both swaps.Good luck!
93s13
Car: 1990 s13, 1993 s13
buy my ca with xtra parts for $2,000
JoeKart
Car: 240sx (180sx)
93s13 wrote:buy my ca with xtra parts for $2,000
i would realy think about it if i wasnt in germany right nowthats the main reason im thinking about the ca because thats what the german version has and the show up wrecked in the junk yards every so often
but what i rely want is the more powerbut would like to do it as afforable as possible and i just figure that the ka will cost morei figure i want about 300-350 hp and from what ive seen here the ca can do itplus the ca has to be a little more rare once i get back to the great u.s. of a
dvd
if you want more power get a sr or boost your ka. also, why do you want 300hp? any paticular reasons?
JoeKart
Car: 240sx (180sx)
dvd wrote:if you want more power get a sr or boost your ka. also, why do you want 300hp? any paticular reasons?
i figure that 300 should be easy enough to live with every day and still be able to track also
300 sounds like a good # to me
89'ClubK's
You can throw down those #'s with a T28 or T3 on your boosted CA.Just make sure to replace all the essentials, other wise the 300 hp. won't last. Good Luck!
JoeKart
Car: 240sx (180sx)
89’ClubK’s wrote:You can throw down those #'s with a T28 or T3 on your boosted CA.Just make sure to replace all the essentials, other wise the 300 hp. won't last. Good Luck!
essentials like what?
89'ClubK's
All gaskets, hoses, and Belts (Well, the CA has a timing belt, the KA has a chain). Most CA18's have around 50-70k miles on them. It may be hard to find a KA with the same milege. The KA has higher compression being a factory NA engine, but also has 260cc injectors. Upgrade injectors & fuel pump are a must. The CA has 370cc & can withstand 13lbs. of boost. Due to the lack of displacment the CA will need more tuning than the KA to reach your #'s. But it is possible...
JoeKart
Car: 240sx (180sx)
well 300 isnt nessisary but i would like to be able to do about a 13-14 sec 1/4be able to do drift like crazyness if i feel like burning some rubbersand be able to hit the road courses and kick but but then agian if doing a 14 1/4 will take much more than 300 i could settle i just want to be fast
JoeKart
Car: 240sx (180sx)
ok so i am looking at getting a ca18det with a pfc fconit needs a turbo and head gasket
now heres my ?'s what series/brands turbos will bolt to the stock mani?and any good sugestions on whre to buy it would be greatalso the guy selling it said i should get arp head studs im pretty sure thats nessasary but where cam i get them?also does any one know how far the head can be shaved down?and also any other good sites for ca18det parts and accessories would be great.
also i have a bee-r racing rev limiter has anyone hooked one of these up befor?
JoeKart
Car: 240sx (180sx)
any one please
89'ClubK's
Any turbo w/ a T25-T28 flange will bolt up to the stock manifold. The Garrett GT-series (Disco Potato- GT28RS) are a popular choice, as are the SR turbos. You don't need to buy head studs as a nessecity, rather than for reliability. The factory ones are fine until you hit big #'s. Why do you want to shave down the head? to lower compression? this can be accomplished w/ a Grex or Tomei metal headgasket. Choose your size @ TakaKaira.comMUCH less work than machining! Good Luck!
JoeKart
Car: 240sx (180sx)
thanks i thought the potato would workand the head thing because the head gasket was blownwe'll see what happens
JoeKart
Car: 240sx (180sx)
no has the bee-r rev limiter
drk_fly
sorry for jacking this thread in advance. but heres a quick question. since the ca18 has lower compression, does this mean that it will get better mileage than the ka24?
